Files are Not Getting Transfered by Shell Command
Sachin Bankar
Hi All,
We are using WinSCP 4.3.4 . When we run below command from command shell it runs fine
Command IS as Below:-
C:\Program Files\WinSCP\winscp /command "option transfer ascii" "option batch off" "option confirm off" "open sftp://ftpuser:xxx@1234@172.17.xxx.xx" "get /NCBOUT/DBMX0914.002.500 I:\NCBReverse\" "get /NCBOUT/CSOX0914.002.500 I:\NCBReverse\" "get /NCBOUT/CFOX0914.002.501 I:\NCBReverse\"  "cd /NCBOUT/" "rm DBMX0914.002.500" "rm CSOX0914.002.500" "rm CFOX0914.002.501
But when same is tried through VB6.0 code it does not move files from SFTP location. From Some days before our SFTP application was working fine but from couple of weeks it is not transferring any files. I have attached screen shot of our code snippet. Can you please guide us on this.
Below is snippet of Our Code(VB 6.0)
 dretval = 0
 sCommand = "C:\Program Files\WinSCP\winscp /command ""option transfer ascii"" ""option batch off"" ""option confirm off"" ""open sftp://" & Username & ":" & Password & "@" & IpAddress & """ ""get " & sSFtpOutArea & objFileList1.Item(1) & " " & LocalPath & """ ""get " & sSFtpOutArea & objFileList1.Item(2) & " " & LocalPath & """ ""get " & sSFtpOutArea & objFileList1.Item(3) & " " & LocalPath & """  ""cd " & sSFtpOutArea & """ ""rm " & objFileList1.Item(1) & """ ""rm " & objFileList1.Item(2) & """ ""rm " & objFileList1.Item(3) & ""
dretval = Shell(sCommand)
If dretval = 0 Then
  WriteToSFTPLog ("Shell Command didn't work in Case4 " & Format(Date, "DD/MM/YYYY"))
            iresult = 0
Else
            iresult = 1
            hprog = OpenProcess(GENERIC_ALL, False, dretval)
            WaitForSingleObject hprog, INFINITEEnd If
end if
Re: Files are Not Getting Transfered by Shell Command
