WinSCP .EXE V5.1.4.0 Does not Match Assembly V5.2.0.0
Hi folks,
Just downloaded the latest WinSCP and .NET Assembly Automation versions. Seems there is an incompatibility issue
Regards,
Bill
Just used the standard PowerSshell script provided.Exception calling "Open" with "1" argument(s): "The version of c:\program files\winscp\winscp.exe (5.1.4.0) does not match version of this assembly c:\program files\winscp\WinSCP.dll (5.2.0.0). You can
disable this check using Session.DisableVersionCheck (no recommended)."
Regards,
Bill
