Synchronizing last file only
Hi everyone,
we're using the "synchronize local" command to be able to sync a server with a local directory.
Does anybody have an idea how to sync the last modified file only instead of syncing the whole directory.
I can't figure out how to do it with the time stamp nor do I come up with another solution.
Thanks a lot
Felix
Re: Synchronizing last file only
There's no option to synchronize last file only automatically.
You can retrieve the last file from listing using some script or using WinSCP .NET assembly, compare the timestamps and do the synchronization manually.
https://winscp.net/eng/docs/library
Or you can select "recent" file(s) using time file mask constraint:
https://winscp.net/eng/docs/file_mask#size_time
