How i can connect to a session
alankar
bangalore
I want to create a new session from a dotnet (c#) program.
Not intended to use existing saved session,want to prompt user to provide the desired credentials.
Any pointers would be very helpful.
Thanks & Regards
Alankar Singh
Re: How i can connect to a session
First, WinSCP .NET assembly is probably not a good fit for use from GUI applications.
Please read
https://winscp.net/eng/docs/library
Anyway, you need to implement the prompts yourselt and then feed the data to SessionOptions class. There's no support for prompts in the library itself.
