need help on excluding a specific file name during sync
Arjun
Sri Lanka
hi,
i need to exclude *_LTR_* and *_TOB_* from my sync list and not able to do this,
tried these but none helped (both style)
option exclude "[A-Z]_LTR_[A-Z].gz"
option exclude "?_TOB_?"
pls help
Reply with quote E-mail
Re: need help on excluding a specific file name during sync
The current syntax in the latest version of WinSCP is:
synchronize -filemask="|*_LTR_*; *_TOB_*" ...
Though the "option exclude" should still work, althought it is deprecated.
Arjun
Sri Lanka
sorry, couldnt catch, kindly could you pls give an example
my script looks like this at the excluding area,
i tried both the "?" and "*" to check but both failing to [b]exclude [/b]
option transfer binary
option exclude ".removed_logs"
option exclude "?_S17-?"
option exclude "?_TS_?"
option exclude "*_LTR_*"
option exclude "*_TOB_*"
synchronize local E:\Logs\ /Incoming
an example would help i guess ..
[quote="prikryl"]The current syntax in the latest version of WinSCP is:
synchronize -filmask="|*_LTR_*; *_TOB_*" ...
Though the "option exclude" should still work, althought it is deprecated.[/quote]
First, I have edited my response, it should be -filemask=.
Even if you insist on using deprecated "option exclude", you need to combine all masks into one. What you are doing that that every call to option exclude overwrite the previous value. They do not add-up. See https://winscp.net/eng/docs/scriptcommand_option
E.g.
option exclude ".removed_logs; *_TOB_*; *_S17-*"
