Turning Off the .Part file option using .NET
TESTUSER
We are testing the use of your application for all of our proticals and it appears to work fairly well. We have encountered a problem recently with a partner that does not allow the rename of the .PART file to the actual file name when the transfer completes.
I do not see a switch for shutting this feature off using VB .NET. What options are available to work around this issue? The partner refuses to change it's permission settings.
We have version 5.0.7.2268 installed.
Re: Turning Off the .Part file option using .NET
This request is tracked here:
https://winscp.net/tracker/834
I can provide you development version of WinSCP for testing, if you send me an email. Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
