WinSCP Drag and Drop to Windows 7 Windows Explorer
Madu
When dragging and dropping files from WinSCP to the Windows Explorer folder, the files aren't get copied. Instead a scpXXXXX folder get created.
O/S: Windows 7
WinSCP: 5.13
Madu
Description: Attached is a screenshot of error window from WinSCP and the folder it creates.
Re: WinSCP Drag and Drop to Windows 7 Windows Explorer
Did you install WinSCP or are you using Portable executable?
Did you restart your machine since you have installed WinSCP?
