"Invalid access to memory" error when renaming remote files
klonos@...
When uploading a file to a remote directory and while renaming another file in the remote directory (i.e. click once to select it and then click a second time to get into rename mode), as soon as the transfer finishes, there is an "Invalid access to memory" error message shown repeatedly in a modal dialog. There's no way to quit winscp because clicking on the "ok" button brings up the same modal again and again.
Note: In order to reproduce the issue, the following conditions are required:
- a remote file needs to be in rename mode
- the file transfer needs to start before the rename begins
- the file transfer needs to finish while the file is still in rename mode
Re: "Invalid access to memory" error when renaming remote files
SINEKT
This is still unsolved. Still happening with the latest version. Also happens when the remote connection is lost (for example, server reboot).
