get file error
munish259272
india
get file error
this is what i did but get is not working
i am into winscp from a windows machine to a linux box(scp:auto_root:password@10.39.5.41)
option transfer binary
open scp:auto_root:pyramid@10.39.5.41
winscp> get abc.sh c:\
abc.sh | 0 KiB | 0.0 KiB/s | binary | 0%
Can't create file 'c:\abc.sh'.
System Error. Code: 2.
The system cannot find the file specified
(A)bort, (R)etry, (S)kip, Ski(p) all:
Re: get file error
Can you script access the c:\ at all?
I.e. can you add "lls C:\" before the "get" and attach session log file showing the script run?
