date variable in script file
murrayb3024
We create a daily file that I need to upload to a vendor. I can hard code the file name and that works but it changes daily so I need to send a file like:
c:\myfilepath\myFile_20130122.txt where the date portion changes daily and needs to be yyyymmdd.
I am not having luck with that part. Any help is appreciated.
mjb0622
Date parameter within text
Does anyone have a sample of this solution. I am trying to do the same with a date.
The file name cahnages by day and i need to update several systems with the same file.
How do I pass the date to the text file?
Re: Date parameter within text
See example here.
https://winscp.net/eng/docs/script_download_timestamped_filename
Or even better, use WinSCP .NET assembly:
https://winscp.net/eng/docs/library
