Syncrhonise local fails
amediacompany
I'm using WinSCP 5.1.3 and this is failing. I was using 5.1.2 and it should have worked, but stopped about a month ago. I can't work out why as the remote directory has new files every 2 days.
Intention:
1) Login to the remote server
2) copy the database backups* to the local machine.
*the files are *.sql.gz files (gzipped SQL files) in dated directories (e.g. 2012-12-15/*.sql.gz)
I thought that the filemask was causing the problem, but I can't see that being a problem as removing it does *nothing* I get *no* error messages at all, and see the synchronise command taking stock of the local directories, but never downloading remote directories/files. I've checked that the files exist on the remote server.
Any thoughts?
# DB Server             #
open "DB server"
option transfer
option batch off
# just to make this clear
# local directory
lcd "C:\Backups (local)\database backup"
# remote directory
cd "/media/db-backup"
# copy remote to local at 1600kbips to not knacker the server
# pipe excludes sql files as they're not complete
# see https://winscp.net/eng/docs/file_mask
synchronize local -speed=1600 -filemask="|*.sql"
# close the session
close
    Re: Syncrhonise local fails
    amediacompany
    Log file is emailed to you
    I've emailed the log to you, and removed a couple things (server names) from the logs.
    It seems that if a directory actually exists locally, then the synchronise works, but I would expect it to replicate new directories that are on the remote server.
    Email subject of what I sent: [b]debug log for "Syncrhonise local fails"[/b].
    Server details:
    1) ubuntu 11.10 with SSH daemon up to date
    2) Centos 5.5
    on that basis, it does not appear to be a server related issue
    Re: Log file is emailed to you
    As I wrote, WinSCP does not create the target directoy. It has to exist prior to synchronization. It creates new subdirectoris in the target directory though.
    So I believe there's no issue.
    amediacompany
    But here the remote and target directories *do* exist. It's the subdirectories that are not created even though remote files which don't exist should be matched. It's that which confuses me.
    Remotely I have:
    [remote]/25-01-2013
    Locally the subdirectory does not exist, but the target directory does exist, so I would expect that WinSCP creates: [target]/25-01-2013
    amediacompany
    An update. Martin and I have had a look at my debug log, and it seems that one of my sessions failed with a permissions error, and I thought I had not changed things. Apparently at least one of the files I had running was in use by another process.
    We're not sure where the problem is, but in case anyone else has a similar problem, please look in the debug log for
    System Error. Code: 32.
    AND
    Can't create file
    I'm checking what user my script runs with; it should be 'me', and will update this thread if I find anything interesting/helpful
