Setting to NOT remember the syncrhonized browsing setting
washcp
In the older version of WinSCP, the state of the synchronized browsing was never saved for me on exiting. Now with 5.1.1 the state is saved and I do not want it to be on by default. I want it to be OFF. I want to be able to load a session and then turn it on when needed and not have to look and turn it off if I had had it on the last time I used that session. I had hoped that disabling the Remember last used directory would disable the remembering of the synchronized browsing but it doesn't.
How can I either disable the automatic saving of the session settings and only have them updated when I manually save them or else turn off the auto update of the synchronized browsing state?
Jpm
Re: Setting to NOT remember the syncrhonized browsing setting
Related to this:
I also want that Under Windows 7/8 the WinSCP.ini be updated.
Currently it is stored under the "Program files\..." and as such cannot be modified unless starting WinSCP with administrator rights.
Thanks for your post.
https://winscp.net/tracker/963
Jpm wrote:
Related to this:
You can set the path to an INI file using /ini command-line switch.
See also
https://winscp.net/tracker/817
