getting SFTP linux server current time using .NET assembly
Sasidharan9513
Hi There,
I am using .NET assembly to connect to the linux server from windows server.
I am able to upload / download files from the linux server.
Is there a way to get the sftp linux server current time with the help of winscp .net assembly?
my requirement is that i need to get the sftp linux server current time and download only the files which are 15 minutes older.
any comments/suggestion would be helpful....
Regards,
S.Sasidharan
Re: getting SFTP linux server current time using .NET assembly
SFTP protocol does not provide such information.
Anyway, the WinSCP .NET assembly should convert the remote file timpstamps to local time, so you can safely compare the timestamps against current local time.
Sasidharan9513
Hi There,
I am getting the linux server time using the session execute command.
session.ExecuteCommand("date")
its getting the linux server time.
is it a right way of doing?
Regards,
S.Sasidharan
