Synchronize failing at 99% on large file
GreenWaterboy
Hello
I have a script that executes the synchronize command to sync up a folder. I have been tinkering with it over 2 weeks changing timeout values and stuff and the script consistently will download all the small files, but fails at 99% when downloading the Large file (67 GB). If I do not manually delete the incomplete large file it will skip it the next to the script runs.
Here is my script
// Configuration
// Session to connect to
var SESSION = "";
// Path to winscp.com
var WINSCP = "C:\\WinSCP\\winscp.com";
var filesys = WScript.CreateObject("Scripting.FileSystemObject");
var shell = WScript.CreateObject("WScript.Shell");
var logfilepath = filesys.GetSpecialFolder(2) + "\\" + filesys.GetTempName() + ".xml";
var exec;
// run winscp to sync folders
exec = shell.Exec("\"" + WINSCP + "\" /log=\"" + logfilepath + "\"");
exec.StdIn.Write(
    "option batch abort\n" +
    "open \"" + SESSION + "\"\n" +
    "synchronize local -delete c:\localfolder /hostfolder \n" +
    "exit\n");
// wait until the script finishes
while (!exec.StdOut.AtEndOfStream)
    WScript.Echo(exec.StdOut.ReadAll());
if (exec.ExitCode != 0)
    WScript.Echo("Error downloading " + filenameLatest);
    WScript.Quit(1);
This is the output I am getting on the transfer for that file
'/hostfolder'  Synchronizing...  Local 'C:localfolder' <= Remote '/hostfolder'  bigfile.bigfile |   64756707 KiB |   70.8 KiB/s | binary |  99%  Lost connection.  12-29-12  07:48PM
I have other scripts that pull larger files down using a modified version of this script https://winscp.net/eng/docs/script_download_most_recent_file
I would like to keep using synchronize though because the folders contents are constantly changing and writing a script to synchronize it would be a pain.
Here is the information for the Host and Client
Host
IIS7 FTP
Windows Server 2008 R2
Client
WinSCP version 5.1.2 (Build 2816) portable
File protocol: FTP
Encryption: SSL/TLS Implicit encryption
Connection: passive mode
Timeouts: 200 seconds
Keep Alives: Executing Dummy... 31 second (originally was off, turning it on didnt change anything)[/list][/code]
Re: Synchronize failing at 99% on large file
JSMTNY
USA
Synchronize disconnect when uploading Large Files
I am having the same issue with sync of large files upload failure when reaching 99% progress
Script Used:
option batch abort
open ftp://<Server>:<Pwd>@<IP>
option transfer binary
synchronize -filemask="*.bak" -criteria=none -speed=600 remote "c:\backup\" "/Backup/"
close
when reaching 99% winscp loose the connection, then retry to connect and report 100%
This happens on large files > 100mb
The FTP server used is QNAP Turbo NAS.
I use the console command line winscp.com version 3.2.1.2735 (provided with winscp 5.1.1)
Thank you,
john
Re: Synchronize disconnect when uploading Large Files
The same response as above:
