Saving "openned" files using Binary
Derek A
Is it possible to open a file (example MS Excel), edit the file, and then save it using Binary Upload?
Re: Saving "openned" files using Binary
It should be possible by double-clicking the file. However there is a bug making it save in ascii mode afterwards, which corrups the file.
It will be fixed in the next version.
