Get <file> error
NRif
Get <file> error
WinSCP Version 5.1.2 (Build 2816)
Using WinSCP.com, command:
get <file>
I receive the error: "Can't create file 'C:\....\<file>'. System Error. Code: 2. The system cannot find the file specified.
However the command:
stat <file>
returns information about the file. Also using the GUI, using SCP, the file transfers just fine when I drag and drop.
I have tried the 'get' command from within the directory where the file is located and from outside, both with the full file path as well as just the filename (from inside the directory). Nothing seems to change the error message.
Thanks.
Re: Get <file> error
It looks like WinSCP cannot create local file to store the downloaded file to. What is the full local path?
