SR for Scripting sync (file is detected as new but not updat
eblain@novavision.ca
Montréal
Version 5.1.2
Problems founded in version 5.1.0
I have a very simple script that is synching a remote folder on a Linux machine to a local folder on a windows server 2008. (Remote->local).
If a local subfolder is deleted, it will properly sync, but if only a remote file changed, it is not updated localy..
*However, the sync option from the GUI seems to be working properly and if I look into the log, I see the modified file is detected as new but it is not copied?
Script:
(SFTPCommand.txt)
Open eblain@anxlysis.isp.novavision.ca
option transfer binary
synchronize local "D:\Backup\anxlysis" /srv/public/
(Launcher.bat)
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /script="D:\Program Files\backup_anxl
ysis\SFTPCommand.txt" /parameter
LOG >3Mo so I have included only the begining and the related information:
. 2012-12-17 15:41:15.486 Collecting synchronization list for local directory 'D:\Backup\anxlysis\novavision' and remote directory '/srv/public/novavision', mode = 1, params = 2
. 2012-12-17 15:41:15.487 Local file 'D:\Backup\anxlysis\novavision\.' [2012-12-17T20:39:58.045Z] [0] excluded from synchronization
. 2012-12-17 15:41:15.487 Local file 'D:\Backup\anxlysis\novavision\..' [2012-12-17T20:39:58.045Z] [0] excluded from synchronization
. 2012-12-17 15:41:15.487 Local file 'D:\Backup\anxlysis\novavision\00085D13F85B.cfg' [2012-10-11T17:04:08.000Z] [7888] included to synchronization
.............etc
. 2012-12-17 15:41:15.489 Local file 'D:\Backup\anxlysis\novavision\aastra.cfg' [2012-12-17T19:38:42.000Z] [4690] included to synchronization
..............Etc
> 2012-12-17 15:41:15.748 Type: SSH_FXP_OPENDIR, Size: 46, Number: 1825035
< 2012-12-17 15:41:15.749 Type: SSH_FXP_STATUS, Size: 24, Number: 1824772
. 2012-12-17 15:41:15.749 Discarding reserved response
< 2012-12-17 15:41:15.751 Type: SSH_FXP_HANDLE, Size: 13, Number: 1825035
> 2012-12-17 15:41:15.751 Type: SSH_FXP_READDIR, Size: 13, Number: 1825292
< 2012-12-17 15:41:15.755 Type: SSH_FXP_NAME, Size: 2481, Number: 1825292
> 2012-12-17 15:41:15.755 Type: SSH_FXP_READDIR, Size: 13, Number: 1825548
< 2012-12-17 15:41:15.757 Type: SSH_FXP_STATUS, Size: 28, Number: 1825548
< 2012-12-17 15:41:15.757 Status code: 1
> 2012-12-17 15:41:15.757 Type: SSH_FXP_CLOSE, Size: 13, Number: 1825796
. 2012-12-17 15:41:15.773 Remote file '/srv/public/novavision/aastra.cfg' [2012-12-17T20:41:01.000Z] [4683] is modifed comparing to local file 'D:\Backup\anxlysis\novavision\aastra.cfg' [2012-12-17T19:38:42.000Z] [4690]
. 2012-12-17 15:41:15.776 Local file 'D:\Backup\anxlysis\novavision\temp' [2012-12-17T20:05:42.227Z] [0] is new
Reply with quote E-mail
Re: SR for Scripting sync (file is detected as new but not updat
Can you attach complete log file both from GUI and script? Ideally for sample synchronization of folder with one file only.
