Sync syncing unchanged files
I've got a very simple script to sync with remote. Right now there are only 5 files in the folder i'm syncing and none of them have changed in a day or so. The first time I sync, it synced all 5 files. However, now it seems to sync two of the five files even though they haven't changed. If I run sync through the GUI it seems to work correctly, confirming that "no differences have been found". The command i'm using is:
synchronize remote K:\redikerbackups /private/adminplus
I also tried synchronize -criteria=time remote K:\redikerbackups /private/adminplus
