login timeout with ftps (pure-ftp server)
jseymour
I am a longtime user of winscp. We have secured our ftp server with ssl using the pure-ftp server. I had a user recently that complained that if they typed in the password they would get a time out message. At the time I was still on the 4x version and could not duplicate the issue. I discovered that the user was using the new 5x version which I upgraded to and the issue happens regularly.
We are using ssl explicit encryption
The error I get is:
Timeout detected.
Connection failed.
User ftpdown2 OK. Password required
I had 5.1.1 installed and it seemed that if I copy and pasted the password it ould not timeout - now with 5.1.2 it seems to never work.
Ithe 4x version never had a problem and I can connect without issues using filezilla. No timeouts are set on the server - except a 15 minute idle session timeout.
Re: login timeout with ftps (pure-ftp server)
Please attach a somplete session log file both using successfull session in WinSCP 4 and unsuccessful using WinSCP 5. Thanks.
