Directory inaccessible if parent directory is inaccessible
Rakushun
Dear WinSCP team,
there seems to be a problem in WinSCP concerning entering directories. This is a rather old bug, I have always had it in all the WinSCP versions (up to and including 5.1.1), but now I want to pass it to you in hope it is fixed.
In our university, we have the situation that some parent directories are inaccessible while the subdirectories can be accessed. So everybody, who looks into the home directory of a user (e.g. /home/user/myboss) is not able to read the directory. However, if you 'know' the path (e.g., /home/user/myboss/ourcommonpaper), I can enter the directory with a "cd" command using putty, list the directory with "ls" and copy the data to my home directory using "cp". However, I cannot enter the directory with WinSCP. If I enter a path like "/home/user/myboss/ourcommonpaper" in the address bar on top of WinSCP, I get the error message
Command 'pwd'
failed with return code 1 and error message
pwd: cannot open directory `..': Permission denied.
It seems that WinSCP requires the parent directory to be accessible to access subdirectories, which is not the case here. This is a rather annoying situation as it requires me to copy all the data to my home directory before I can copy it to my Windows machine with WinSCP. The parent directory "/home/user/myboss" has permissions "0710", the subdirectory "/home/user/myboss/ourcommonpaper" and all its subfolders "0755".
Can you help?
Regards,
Michael
P.S.: The connection options are:
Remote system = SunOS jerusalem 5.10 Generic_138888-03 sun4u sparc SUNW,Sun-Fire-V440 Solaris
Session protocol = SSH-2
SSH implementation = OpenSSH_4.6
Encryption algorithm = aes
Compression = ZLib
File transfer protocol = SCP
Server host key fingerprint
ssh-rsa 2048 1f:ed:e6:f9:ad:4b:49:17:87:e7:e6:b4:ce:e5:dc:d9
Can change permissions = Yes
Can change owner/group = Yes
Can execute arbitrary command = Yes
Can create symlink/hardlink = Yes/Yes
Can lookup user groups = Yes
Can duplicate remote files = Yes
Can check available space = No
Can calculate file checksum = No
Native text (ASCII) mode transfers = No
Re: Directory inaccessible if parent directory is inaccessible
Please attach a full log file showing the problem.
WinSCP needs to use pwd command to determine the current working directory. But with your serup the pwd command does not work. Actually I was not able to reproduce your setup. What group owns the myboss? Are you member of that group?
Rakushun
Hello Martin,
myboss and me, we are both in the same group. If I use a standard Putty session, there is also no problem entering "pwd" in "/home/user/myboss" or "/home/user/myboss/ourcommonpaper", it works quite well.
Another thing I just recognised: The problem only appears if I use the SCP protocol to connect to the server. If I connect via SFTP, there is no problem entering "/home/user/myboss/ourcommonpaper" and viewing the content.
Regards,
Michael
Rakushun
Rakushun wrote:
Hello Martin,
However, if I use Putty, I get an error using the following commands:
server: /home/user/thisisme[213]>cd /home/user/myboss/ourcommonpaper
server: /home/user/myboss/ourcommonpaper[214]>pwd ..
pwd: ignoring non-option arguments
server: /home/user/myboss/ourcommonpaper[215]>
Regards,
Michael
Rakushun
Another thing to note:
The machine I connect to is not a Linux machine. It is a SunOS 5.10 machine.
If I connect to a Linux machine which has also access to the same home directories, it seems to work.
Regards,
Michael
Rakushun
Ok, some deeper analysis:
Here the shell output if I connect to a linux machine:
linuxserver: /home/user/thisisme[248]>cd /home/user/myboss/ourcommonpaper
linuxserver: /home/user/myboss/ourcommonpaper[249]>pwd
linuxserver: /home/user/myboss/ourcommonpaper[250]>unalias pwd
linuxserver: /home/user/myboss/ourcommonpaper[251]>pwd
/home/user/ture/tex
linuxserver: /home/user/myboss/ourcommonpaper[252]>
And here a bit of shell output if I connect to the sun machine:
server: /home/user/thisisme[256]>cd /home/user/myboss/ourcommonpaper
server: /home/user/myboss/ourcommonpaper[257]>pwd
server: /home/user/myboss/ourcommonpaper[258]>alias
pwd echo $cwd
server: /home/user/myboss/ourcommonpaper[259]>unalias pwd
server: /home/user/myboss/ourcommonpaper[260]>pwd
server: /home/user/myboss/ourcommonpaper[261]>
Regards,
Michael
