FAR plugin and putty sessions
gerhardw
Hello Martin!
First of all congratulation to your great work.
Is it currently possible to import (or better use) putty sessions? That's the feature I miss.
Thank you for the answer.
Ciao,
Gerhard
Re: FAR plugin and putty sessions
You cannot do this with the plugin. However you may import the sessions with WinSCP application. Use button "Tools" on "Stored sessions" tab of login dialog.
