Keep Remote Directory Up to Date -- auto skip files in use?
chippy
I'm using the Keep Remote Directory Up To Date function, and it seems to work well. However, I keep getting an error message indicating that the file is in use (it's a folder accessed by a number of users). I have to click "skip" and then it continues with the normal process. However, this defeats the purpose of having an automatic sync--I have to manually intervene to keep the process going.
Is there any way to make WinSCP automatically click "skip" (or just ignore these files) so I don't have to manually intervene?
Thanks.
Chippy
hmmm
now it keeps popping up a "x errors occurred during your last process. Do you want to see them?" Is there any way to avoid this dialog box?
To be clear, it looks like WinSCP is detecting a change whenever someone even opens one of the files in the sync directory, then generates an error because that file is open and it presumably can't transfer it--which is odd behavior.
Re: hmmm
WinSCP definitely does not detect, when file is open. But some applications (notably Microsoft Excel) have odd behaviour, where they update file timestamp to current time, whenever you open the file. Reverting the timestamp to its original value, when you close the file without saving it. Then, WinSCP would behave as you describe. Can it be the case?
Chippy
Yes, they are all excel files
Indeed excel files are the ones causing the problem. Is there any sort of workaround?
Re: Yes, they are all excel files
Unfortunately, no. Any hint for workaround?
