Arithmetic Overflow
RedJungle
Napier, New Zealand
Arithmetic Overflow
When attempting to open a session with a sFtp site I am getting an Arithmetic operation resulted in an overflow Error
Specific information is
Visual Studio 2012
.Net Framework 4.5
WinSCP 5.1.1
Renamed WinSCP.dll to WinSCPnet.dll
WinSCP.exe, WinSCP.dll and WinSCPnet.dll are in Bin directory. -> see https://winscp.net/forum/viewtopic.php?t=11808 for reason for 3 dlls
WinSCPnet.dll is correctly registered in Project and Project is compiling.
I am able to access and use the site by connecting directly with the WinSCP.exe, but when I attempt to use the .net dll, I get the following error.
System.OverflowException was caught
HResult=-2146233066
Message=Arithmetic operation resulted in an overflow.
Source=mscorlib
StackTrace:
at System.IntPtr.ToInt32()
at WinSCP.ConsoleCommStruct..ctor(Session session, SafeFileHandle fileMapping)
at WinSCP.ExeSessionProcess.AcquireCommStruct()
at WinSCP.ExeSessionProcess.InitializeConsole()
at WinSCP.ExeSessionProcess.Start()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at Scantron.IPaper.BL.FtpDownload.TestConnection() in c:\Projects\BST Clients Direct\Scantron\IPaper\IPaperRinconBridge\FtpCsvBL\FtpDownload.cs:line 64
InnerException:
If you would be good enough to post up the source for the WinSCP.dll I would be more than happy to do a push to try to fix this problem
Re: Arithmetic Overflow
I have sent you an email with source code to address you have used to register on this forum.
Gophrntz
Is there a resolution to this issue, I am seeing it as well. I am using PoSH (the example directly from this site) and receive the "Arithmetic operation resulted in an overflow" error when attempting to call $session.Open($sessionOptions).
thanks much.
[UPDATE] - Was on my Win8 machine using x64 version of Powershell.exe. Switch to x86 and it works correctly.
I have sent you an email with a dev version of WinSCP to address you have used to register on this forum.
devoured wrote:
I am seeing this error as well when attempting to open a session. How can I work around this issue?
mprothme
Fayetteville
I am also getting the same error
I am also currently running into this error. I've noticed that when I build this project in 32 bit mode (which I cannot do for production) that I don't get this error. Has this issue been addressed in a new release? Or how should I go about fixing this error?
Thanks!
Re: I am also getting the same error
This has been fixed in 5.1.3. What version are you using?
