Cannot connect when remote folder was deleted
JQu
WinSCP v.5.1.1
WinSCP remembers path on remote machine and when connects again, remote path is the same as was last time.
Problem occurs when the remote folder was deleted - winscp cannot connect until I create deleted folder or
delete remembered path from system registry.
Sorry for my terrible English.
regards,
JQu
Re: Cannot connect when remote folder was deleted
Can you please attach few screenshots showing that? And a session log file. Thanks.
JQu
I think I know what the problem is. There is QNX4 operating system on the remote machine, which generates problem.
When WinSCP try to set current directory, during connection establish, executes command:
cd "/AAAA" ; echo "WinSCP: this is end-of-file:$?"
on Linux machine the response is:
-bash: cd: /AAAA: No such file or directory
WinSCP: this is end-of-file:1
but on QNX4 machine the response is:
/AAAA: bad directory
there is no "WinSCP: this is end-of-file" in reponse.
WinSCP timeouts when waiting on it.
It seems that QNX4 shell breaks executing commands on cd command error.
Look at the attached log.
regards
