tranfer of zip file fails via script however works fine with
dgibson26
London
HI have a script which exports data then zip and then transfer via winscp however when i comes to transfer it fails, port 22 is open
any advice will be appreciated
Re: tranfer of zip file fails via script however works fine with
Please attach a full log file showing the problem.
dgibson26
London
Hi managed to get this working
issue was script rather than winscp functionality
Script used was copied from 64bit machine into 32bit and where there is a ref to winscp program file to initiate transfer was "programfiles~2" when changed to "programfiles~1" all works.
Thanks again for response
