Connected with putty but not with WinSCP
Gil
I try to connect to my IPCOP with WinSCP, but it doesn't works.
This is the log:
. Session name: 192.168.1.1
. Host name: 192.168.1.1 (Port: 222)
. User name: gilles (Password: Yes, Key file: No)
. Transfer Protocol: SFTP
. Agent forwarding: No; TIS/CryptoCard: Yes; KI: Yes
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs:
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "192.168.1.1"
. Connecting to 192.168.1.1 port 222
. Server version: SSH-2.0-OpenSSH_3.7.1p2
. We claim version: SSH-2.0-WinSCP-release-3.5.6
. Waiting for data timed out, asking user what to do.
. Asking user:
. L'hôte ne répond plus depuis 15 secondes.
. Attendre encore 15 secondes ? Appuyer sur 'Abandon' pour annuler l'opération en cours. ()
. Attempt to close connection due to fatal exception:
* Interrompu par l'utilisateur
. Closing connection.
* (ESshFatal) Interrompu par l'utilisateur
I tried SCP, SFTP..nothing.
But when i use Putty i have no problems.
What is wrong ?
Re: Connected with putty but not with WinSCP
Bingo !
4x15 secondes exactly.
It works fine now,thank you for your response.
Set the longer "server response timeout" on Connection tab of login dialog.
