Capturing WinSCP return code in the script
Sasidharan9513
Hi There,
Is there any possibility to capture the WinSCP.com commandline return code?
I need to fail the automated process based on the return code.
Can some one let me know the answer/sent me a same script which uses the return code?
winscp.com /console /script="C:\Winscp_testing\WinSCP_script.txt" /xmllog="C:\Winscp_testing\log1.xml"
WinScp_Script.txt has the below code:
# Abort script on errors
option batch abort
# Connect using a password
open sftp://usename:pwd@abc.com
# Change remote directory
cd cps_dev
# Download file to the local directory
mv *.pdf C:\Winscp_testing\
# Disconnect
close
# Exit WinSCP
