Share settings with putty?
axxian
Is there an option to share settings w/ PuTTY ? I know the settings are in exactly the same format in the registry, its just one is in [HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Sessions]
and the other is
[HKEY_CURRENT_USER\Software\SimonTatham\PuTTY\Sessions]
Is there a way for WinSCP to use the session information from PuTTY?
Cheers
Re: Share settings with putty?
You may import session from Putty. See "Tools" button on "Stored sessions" tab of login dialog.
Scotty
This option does not seem to exist...?
How come? You do not have "Stored sessions" tab or Tools button or what?
