filemask for several file type; prbl. within command line
plubarj
WinSCP 4.3.9, Build 1817
Hello
I'm getting in trouble using filemask with the command line to download several file types.
e.g. with the command below returns an error: Missing parameter for cammand 'get'
winscp /command "option batch abort" "option confirm off" "open ftp:/myftp.com" "get -resume -preservetime -filemask="*.m4a; *.wav; *.dct; *.txt" /data/dictate/* c:\temp\" "exit"
But if I put just a single filetype like below, it works
winscp /command "option batch abort" "option confirm off" "open ftp:/myftp.com" "get -resume -preservetime -filemask=" *.txt" /data/dictate/* c:\temp\" "exit"
It's like the semi-column separator was not accepted. I tried many other options witout success. Would someone be able to help me?
Thanks in advance
***WinSCP 5.1.0, build 2625
plubarj
Yeah! Cool! It works so.
Thanks a lot prikryl.
Funny: in my code now, I've got quintuple quotes :mrgreen:
... preservetime -filemask="""""& $fileType &""""" ...
Anna
synchronize remote -filemask="*.csv" in 4.3.9
can I please confirm if this syntax is supported in 4.3.9
WinSCP.exe /command "option batch abort" "open Test" "cd Test01" "lcd \\out" "synchronize remote -filemask=""*.csv""" "exit" /log=C:\temp\log\test.log
thank you
Re: synchronize remote -filemask="*.csv" in 4.3.9
The -filemask switch was introduced in 5.0.6 only. For older versions use "option include". Or even better, upgrade.
