Running multiple Winscp in the same PC
harishg
INDIA
I have created two applications where both applications will try to pull files from SFTP at the same time. The application which will connect to FTP first is able to download files successfully. But the second application is not able to download the files even after the first application completes downloading the file.
Can you please let me know how to download files from SFTP by both application at the same time.
Thanks in advance
Harish G
Re: Running multiple Winscp in the same PC
There's no limitation on WinSCP side. Netiher there's anything special you need to do.
Please post a session log file.
Pratik Bhagat
winscp
what is the reason behind , not running multiple instance of the winscp on the same machine at a time
Re: winscp
Sorry, I do no understand your question (if that is a question).
