Local window disappeared
DTC
Just noticed that the 'local'window disappeared, only the 'remote' window is there.
All was fine after install, problem seems to appear right after installing the 'Zone' firewall. Any help is appreciated.
Re: Local window disappeared
You may have selected "Explorer-like" interface on "Preferences" tab of login dialog. Select "Norton Commander" interface.
