Multi Instance of Winscp.dll
burakalakus
does winscp.dll support multi instances at the same time? I am going to create a new thread for each winscp session and they will work individually.
As I remember it is not possible but I couldn't be sure of this.
Re: Multi Instance of Winscp.dll
You can have multiple instance of Session class. You can use each from a different thread. You cannot use one Session instance from multiple threads at the same time.
