copy and remove files to two ftp servers
viorelrosu
Romania
I'm trying to use a script that copy a csv files to an ftp server then move the same files to other ftp server.
Main problem is that log file generated by winscp.com command contain only info about first connection and about second connection log file (with the same name) is located in lcd command path.
How can I solve this issue (having one log file for both connections)?
Thanks.
Ex(batch file)
@echo off
path=c:\;c:\windows;c:\windows\system32;C:\Program Files\WinSCP
IF EXIST daily_d.log DEL daily_d.log
winscp.com /console /script=taskD.txt /log=daily_d.log
Ex (script tasD.txt)
option batch continue
open x
lcd c:\prognoza\outgoing
put *.csv /prognoza_nou/
open y
put -delete *.csv /
# Disconnect
close
# Exit WinSCP
