winscp syntax help
rookie19
winscp syntax help
Can you tell me what I am doing wrong? The code below is not working:
"E:\Program Files\WinSCP\WinSCP.exe"
option batch on
open username@xxx.edu
cd /cygdrive/E/vol1/dev
put e:\Reporting\dir\test_report.txt
close
rookie19
more information
More information:
How can I combine two .bat files into one?
1. I have a .bat file that has the following syntax:
"E:\Program Files\WinSCP\WinSCP.exe" /script=E:\test folder\test_file.txt
2. The next file is the test_file.txt that has the following syntax:
option batch on
open user@xxx.xx
cd /cygdrive/E/some directory
put e:\some directory\some file*
close
I want to combine the syntax from both files instead of having to run the .bat file that calls to the test_file.
