Drag n Drop on Network Drive
MaGa Deutschland
I used often Drag n Drop operations with WinSCP. In Version 5.0.8 on Networkdrives delete WinSCP only the file. The file don't arrived in new (Sub)folder.
Fishnet_Ian
Drag and Drop Copy (Still) broken
WinSCP version: 5.1.0 (Build 2625)
If I drag and drop from remote system to ROOT of a network drive (Win 2008 R2 server) everything is fine.
If I try the same but to any sub folder e.g. q:\test WinSCP hangs for around four minutes before showing the copy dialog.
Local system is Win 7, remote system CentOS 5.8.
I have attached a log (Debug Level 2) for the time (although there is not much in it apart from a gap in activity)
Regards
Ian
Description: Log file generated at time of problem
Re: Drag n Drop on Network Drive
MaGa Deutschland wrote:
I used often Drag n Drop operations with WinSCP. In Version 5.0.8 on Networkdrives delete WinSCP only the file. the file don't arrived in new (Sub)folder.
Sorry, I do not understand, what is the problem. Can you please try again?
Re: Drag and Drop Copy (Still) broken
I have this same exact problem, even with the latest version installed 5.1.
This is happening on Windows 7 x64 SP1 on three different systems I have.
I'm able to reproduce the issue by trying to drag and drop a file from FTP using Implicit SSL server and dragging into a mapped drive that is at least 3 folders deep. This is a new problem this week, the only change I can think of is that we recently moved the file share they're copying to from Server 2003 to Server 2008 R2. I have verified that the permissions on the share are correct.
You know the problem has occurred right away when you drag and drop you never get the copy dialog box and the application completely freezes. Drag and drop to a local folder works fine.
Can you please assist?
techsupport2012
My post is the previous one, for some reason I was not logged in.
techsupport2012 wrote:
The versions I have found this issue with is 4.3.5, 4.3.7 and 5.1. Anyone have an update for this issue?
