Allow to specify a path for the WinSCP.ini
Hi, I am regularly using WinSCP on different systems. What I find tedious is, that I can not share the settings between them. The registry obviously cannot be shared but also the WinSCP.ini file is put into the Program Files folder (which is not shareable, either, and where it really should NOT sit since it is not writable by normal processes since Win Vista)
WinSCP is already half way there. If only it would allow to specify a path where to store the WinSCP.ini file, then once could place that file into some "cloud folder" (using DropBox or SkyDrive or whatever) and could thus share the settings between several machines. I am doing that with several other tools already and that greatly improved my user experience!
Michael
Michael
