winscp has problems with virtualbox and windows xp
adderbabba
hi at all
when i try to download files from an ftp location, i will see the transfer dialog. when i scan the directory structures, it will not continue... (like a pause)
regards, adderbabba
Re: winscp has problems with virtualbox and windows xp
What does it mean "scan the directory structures"?
Do you mean WinSCP hangs? Indefinitelly? Or temporarily?
o1797230 wrote:
now i registered; will send an e-mail to you in the next minutes...
Thanks. I have responded to your email.
