new version I can use with Xp?
robs
regards future version 5.x I read this:
Dropped support for Windows 2000. Minimal supported version is Windows XP
I can use with Xp? or can have limitattion in the use?
in the nex version (6.x) isn't more possible to use with Xp?
Re: new version I can use with Xp?
As mentioned, Windows XP is supported. No limitations. Also no plans to drop XP support any time soon.
