Get including subfolders
First: thx a lot for that great tool! It works fine except a little problem I cannot manage.
I'm getting in trouble using mask and it seems that I got the exact opposite problem that other reported.
Using a shell command, I just need to download all files of some type from an FTP folder, including its subfolders.
But I can't get the files located in the subfolders.
Acc. to the doc:
Path Mask
When the mask selects files and it makes sense to select them based on directory, you can extend the mask with a path mask. You should separate the path mask from the filename mask by a slash. For example mask /home/martinp/*.txt matches all text files within the directory. To match all text files within subtree, use mask /home/martinp/*.txt; /home/martinp/*/*.txt.
I tried many configuration like this:
/command "option batch abort" "option confirm off" "option include /*/*.txt" "open ftp://myftp.com" "get -delete -resume -preservetime /data/* C:\temp\" "exit"
or that:
/command "option batch abort" "option confirm off" "option include */; *.txt" "open ftp://myftp.com" "get -delete -resume -preservetime /data/* C:\temp\" "exit"
Or without using the mask:
/command "option batch abort" "option confirm off" "open ftp://myftp.com" "get /data/*/*.txt C:\temp\" "exit"
But I cannot get it working.
What I'm I doing wrong?
Thanks in advance
Re: Get including subfolders
What version of WinSCP are you using? Make sure, you have the latest one.
Use just simple mask *.txt.
Also note that you should use -filemask switch instead of the option include (although it is still supported for backwards compatibility).
get -delete -resume -preservetime -filemask="*.txt" /data/* C:\temp\
If it does not help, please attach a complete log file.
plubarj2
Thank you @martin
Apparently, the version I was running 4.3.9 doesn't like the filemask switch:
Unknown switch 'filemask'
I installed the 5.1 and it works great!
Thanks once more for the project and your support. I will donate.
Hushham
Getting specific file extension from all subfolders
Hi Martin,
You have explained everything wonderfully but I am having a trouble in getting specific file from all subfolders.
I am using 5.13.6 & I am using below command to get csv file from the listed folder & its subfolder but it only gets file from the specified folder.
get -delete *.csv C:\Users\hash\Desktop\BI\
I have checked all changes like */*.csv etc.
I have also checked
get -filemask="*.csv" -delete *.*  C:\Users\hash\Desktop\BI\
but of no use.
I want to take all .csv files from folder/subfolder & delete it later on.
Hushham
Pakistan
Just to tell you, I have used all below
get -delete "*.csv" C:\Users\hash\Desktop\BI\
result = No file matching '*.csv' found
get -delete "*\*.csv" C:\Users\hash\Desktop\BI\
result = No file matching '*\*.csv' found
result = it transferred the complete folder including subfolder.
Reply with quote E-mail
This is correct. If it does not work for you, please attach a full session log file showing the problem (using the latest version of WinSCP).
Hushham
Pakistan
Dear Martin,
Thanks for the reply, the log of the below command is attached privately to you. Please check.
Command used is as below. It copied the folder named 1 & 2 as well.
  • logfile.log (14.44 KB, Private file)
Sorry, I got lost.
This is what you wanted, isn't it?
What sounds like the files in subfolders were not downloaded, but you wanted them to. So it seems like now you have what you wanted.
Hushham
Pakistan
Dear Martin,
Thanks for the reply, actually I want the files only and not the folders.
Is there a command who can pick '.csv' files only and not the subfolder?
right now I am getting the subfolders as well.
jwatson151
trying to move files within subfolders without taking the subfolders
Trying to get PDF's only, from unknown folders being created and placed on the FTP. I was successful using -filemask but it transfers the folders as well which I do not want. I am currently trying this syntax but it does nothing and returns no errors. Your help is greatly appreciated.
cd /Test/Exports/
mv * /Staging/
cd /Staging/
get -filemask="*.pdf|*\"  *.* "X:\Workflow\Scans\Documents\Generic"
cd /Staging/
rm *.*
attempted these others as well:
I get no pdf's found error on this one...
cd /Test/Exports/
mv * /Staging/
cd /Staging/
lcd \\1.2.3.4\Data\Workflow\Scans\Documents\Generic
mget */*.pdf
cd /Staging/
rm *.*
**this one executes but no files move and errors are generated.
cd /Test/Exports/
mv * /Staging/
cd /Staging/
get *.pdf "X:\Workflow\Scans\Documents\Generic"
cd /Staging/
rm *.*
cd /Test/Exports/
mv * /Staging/
cd /Staging/
get -filemask="*.pdf|*\" -delete *.*
jwatson151
@Martin. Thanks. I generally stay away from .NET assembly..as it may leave a process running at the database level. My task is to import pdf files. They are being dropped in a /test folder. File A.pdf is within /test/A, file b.pdf is in /test/B and so on. So I'm trying to get the pdf's from within the unknown folders that will be dropped in /test then delete. In order not to get dup's or delete files I have not received yet, I am using a staging folder to move the folders within /test to then move the pdfs out of and then delete the folders and files.
Re: trying to move files within subfolders without taking the subfolders
@jwatson151: I'm not aware of any such problems with .NET assembly. Are you?
Anyway, the link I've posted shows a solution using plain scripting and a batch file.
