File must be specified by the library/file.member.
We are trying to connect to an external server and getting this error message.
The directory we are trying to connect to is /QSYS.LIB/DR1538.LIB
This seems to work fine in Filezilla (we would rather not use this).
> 2012-10-02 14:43:39.005 USER HSP1538
< 2012-10-02 14:43:39.052 331 Enter password.
> 2012-10-02 14:43:39.052 PASS ******
< 2012-10-02 14:43:39.505 230 HSP1538 logged on.
> 2012-10-02 14:43:39.505 SYST
< 2012-10-02 14:43:39.552 215 OS/400 is the remote operating system. The TCP/IP version is "V5R4M0".
> 2012-10-02 14:43:39.552 FEAT
< 2012-10-02 14:43:39.583 211-Feature listing follows:
< 2012-10-02 14:43:39.770 AUTH TLS
< 2012-10-02 14:43:39.770 CCC
< 2012-10-02 14:43:39.770 PBSZ
< 2012-10-02 14:43:39.770 PROT
< 2012-10-02 14:43:39.770 211 End of feature listing.
. 2012-10-02 14:43:39.770 Connected
. 2012-10-02 14:43:39.770 --------------------------------------------------------------------------
. 2012-10-02 14:43:39.770 Using FTP protocol.
. 2012-10-02 14:43:39.770 Doing startup conversation with host.
> 2012-10-02 14:43:39.770 PWD
< 2012-10-02 14:43:39.802 257 "DR1538" is current library.
. 2012-10-02 14:43:39.802 Changing directory to "/QSYS.LIB/DR1538.LIB".
. 2012-10-02 14:43:39.802 Synchronizing current directory "DR1538".
> 2012-10-02 14:43:39.802 CWD DR1538
< 2012-10-02 14:43:39.848 250 "DR1538" is current library.
> 2012-10-02 14:43:39.848 CWD /QSYS.LIB/DR1538.LIB
< 2012-10-02 14:43:39.880 501 File must be specified by library/file.member.
* 2012-10-02 14:43:39.880 (ECommand) Error changing directory to '/QSYS.LIB/DR1538.LIB'.
* 2012-10-02 14:43:39.880 File must be specified by library/file.member.
. 2012-10-02 14:43:40.630 Getting current directory name.
. 2012-10-02 14:43:40.630 Retrieving directory listing...
> 2012-10-02 14:43:40.630 CWD /DR1538/DR1538/
< 2012-10-02 14:43:40.661 501 File must be specified by library/file.member.
. 2012-10-02 14:43:40.661 Could not retrieve directory listing
. 2012-10-02 14:43:40.661 Retrieving directory listing...
> 2012-10-02 14:43:40.661 CWD /DR1538/DR1538/
< 2012-10-02 14:43:40.692 501 File must be specified by library/file.member.
. 2012-10-02 14:43:40.692 Could not retrieve directory listing
* 2012-10-02 14:43:40.692 (ECommand) Error listing directory 'DR1538'.
* 2012-10-02 14:43:40.692 Could not retrieve directory listing
* 2012-10-02 14:43:40.692 File must be specified by library/file.member.
. 2012-10-02 14:43:41.192 Startup conversation with host finished.
. 2012-10-02 14:43:42.770 Disconnected from server
