Problem with using WinSCP behind SOCKS5 Proxy
BernhardK
Vienna
I try to use winSCP 5.1.0 (Build 2625) connecting to an SFTP Server. Because I'm behind a Firewall i would like to use a SOCKS5 Proxy on Bluecoat Appliance.
Using WinSCP without a Proxy (direct connection to Internet) is OK:
This is an log from such an session: Direct_winSCP.log
When using an Socks5 Proxy, I can't connect to the SFTP-Site: Proxy_winSCP.log
I send also my WINSCP.ini.
Maybe you can help me?
-bernhard
Description: This is my WinSCP.ini. I tried to delete the passwords, hopefully I didn't delete to much.
Description: Connection with Proxy dosn't work
Description: Connection to sftp-site without proxy, when on direct internet
Re: Problem with using WinSCP behind SOCKS5 Proxy
Can you please first try to connect using PuTTY or any other SSH client? Please attach a log file for that too.
BernhardK
Vienna
Hi Martin,
I downloaded putty already some days ago,
but I'm not really sure how to use this to test the connection to the sftp-server
-bernhard
BernhardK
Vienna
Hi Martin,
-bernhard
I got this:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.04 14:12:40 =~=~=~=~=~=~=~=~=~=~=~=
connect
SSH-2.0-Pragma FortressSSH 5.0.9.1715
Protocol mismatch.
Looks like the very same problem. Sorry, have no idea how to help you.
