Display filter-icon as greyed backgroud image when filter is
TSM
Hi Martin,
when a filter is used it would be nice, if i could remind myself by seeing a greyed filter-icon in the folder and in the files panel.
Thomas
Re: Display filter-icon as greyed backgroud image when filter is
Thanks for your suggestion.
Do you know that when a filter is enabled, it is shown on the path label?
Hi Martin,
of course I know this - but it can easily be overseen.
And when you switch between tabs then the filter conditions seem to remain effective.
A direct signal in the whole window area as a background picture, which can not
be overseen, would be better.
Thomas
Also Filter button on toolbar is depressed :)
They do not.
rwoeke
South Africa
Disable and enable the remote Filter Shortcut
HI,
I use WINSCP daily and its a wonderful tool! Is there anyway to request shortcut to disable and enable the remote Filter?
thanks
Re: Disable and enable the remote Filter Shortcut
Thanks for your post.
This request has been added to the tracker:
https://winscp.net/tracker/929
