compare w./ subdirs
As my search shows, an often requested feature.
I do not understand enough about the windows command line and the way WinSCP passes parameters to it to try this for myself, but wouldn't going to preferences->commands and changing the command for compare directories to something based on the following:
(source: https://ss64.com/nt/for_r.html )
be a promising approach, with the appropriate fc or comp command in the DO part ?
Please somebody with the expertise have a look into this
FOR /R
Loop through files (Recurse subfolders)
Syntax
FOR /R [[drive:]path] %%parameter IN (set) DO command
Key
drive:path : The folder tree where the files are located.
set : A set of one or more files. Wildcards must be used.
If (set) is a period character (.) then FOR will
loop through every folder.
command : The command(s) to carry out, including any
command-line parameters.
%%parameter : A replaceable parameter:
in a batch file use %%G (on the command line %G)
This command walks down the folder tree starting at [drive:]path, and executes the DO statement against each matching file.
If the [drive:]path are not specified they will default to the current drive:path.
Unlike some other variants of the FOR command you must include a wildcard (either * or ?) in the 'set' to get consistent results returned. In many cases you can work around this by adding a single character wildcard e.g. if you are looping through multiple folders to find the exact filename myfile.txt you could instead specify myfile.t?t
Examples:
Delete every .bak file in every subfolder starting at C:\temp
C:\>FOR /R C:\temp\ %%G IN (*.bak) DO del %%G
List all the subfolders under C:\Work
FOR /R "C:\Work\" %%G in (.) DO (
Pushd %%G
Echo now in %%G
Popd )
Echo "back home"t
