Anti-virus detects supsicious file on WinSCP 5.1 upgrade
nmoore1978
I have upgraded two computers from 4.x to 5.1. Both computers' endpoint security detected an EXE file in the Windows directory following the WinSCP upgrade as suspicious and quarantined the files. The files have different names on the computers.
C:\Windows\is-BFNG4.exe
C:\Winodws\is-OM2NS.exe
Sophos is showing HIPS/RegMod-014 as the reason for the suspicion.
abclab
Re: Anti-virus detects supsicious file on WinSCP 5.1 upgrade
Yes, I experienced the same issue as well. Sophos detected the file in C:\Windows\is-1JK1B.exe
Looks like a false possitive. No reports from other AV.
Please refer here:
To reduce the chance of unwanted detections, Sophos HIPS should be set to 'Alert only' mode for the duration of any software installations.
Can you please submit WinSCP installer for analysis, as suggested, so that they can fix this false possitive?
