File Corruption during the FTP file transfer
viv017
Hi ,
I'm facing an issue with file corruption during the FTP file transfer because the connection lost between two systems . After it reconnects then the partially copied file cannot be overwritten and file transfer moved on with next file . Hence the partially copied file become a corrupted file. Any solution for overwrite the partially copied file due to a connection lost . Please advise .
Thanks.
Re: File Corruption during the FTP file transfer
Please attach a full log file showing the problem.
viv017
Thanks for your reply.
We found the following error in log file.
Error transferring file 'E:\xxxx\xxxx.trn'. ("Copying files to remote side failed.","The process cannot
access the file because it is being used by another process. ")
Please advise , thanks.
Subverionaut
About as helpful as being punched in the face
About as helpful as being punched in the face, like most of these threads, you offer no solution
