Upload 200KB files via WinSCP .NET assembly
nishalkr
I am using WinSCP .NET assembly to upload files via SFTP. On uploading any files larger than 100kb, getting error messages "filepart could not be renamed to target file name, you may try to turn off transfer resume support.. In the .NET source code I added following code to disable the settings:
sessionOptions.AddRawSettings("ResumeSupport", "2")
sessionOptions.AddRawSettings("IgnorePermErrors", "1")
sessionOptions.AddRawSettings("PreserveTime", "0")
But still I am getting the same error message. While uploading it though GUI, I am not facing any issues, but using .NET assembly. I am not able to upload large files.
nishalkr
Rename Permission issue while uploading the file via SFTP
I have downloaded 5.1.3 version of WINSCP.DLL to work with .NET. Use following code to ignore the error messages "filepart' could not be renamed to target file name. We don't have rename permission to the destination SFTP folder.
With sessionOptions
    .Protocol = Protocol.Sftp
    .HostName = FTPAddr
    .UserName = FtpUserId
    .Password = FTPPassword
    .PortNumber = FTPPort
    .SshHostKeyFingerprint = sshHostKey
End With
Let me know, if this issue is fixed already with 5.1.3 version ?
Thank you.
Re: Rename Permission issue while uploading the file via SFTP
It's not. Will be fixed in 5.2, as per the tracker entry above.
joey
5.2 Release Date or Beta Release
Any idea on the release date of 5.2 or beta release? Or, a way to get around the Resume Support using the .Net assembly, Or, even a trial piece of CPP to allow local builds to resolve?
Product is still awesome!!!
Re: 5.2 Release Date or Beta Release
@joey: I can provide you development version for testing. Can you send me an email? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
hjackows
austin
Upload 200KB files via WINSCP .NET assembly
I just downloaded version 5.2 and I am still seeing the same issue. File could not be renamed..
Am I disabling the resume support correctly?
SessionOptions sessionOptions = new SessionOptions()
    Protocol = Protocol.Sftp,
    HostName = ConfigurationManager.AppSettings["sftp.host"],
    UserName = ConfigurationManager.AppSettings["sftp.userName"],
    Password = ConfigurationManager.AppSettings["sftp.password"],
    SshHostKeyFingerprint = ConfigurationManager.AppSettings["sftp.SshHostKeyFingerprint"],
sessionOptions.AddRawSettings("ResumeSupport", "2");
sessionOptions.AddRawSettings("IgnorePermErrors", "1");
sessionOptions.AddRawSettings("PreserveTime", "0");
Thanks Henry
fightingfit99
York
Re: Upload 200KB files via WINSCP .NET assembly
@martin: Hi, I've just tried this I'm getting a message that the ResumeSupport property is readonly. Can you help? Full code:
Dim sftp As New SessionOptions
Dim session As New Session
Dim transfer As New TransferOptions
Dim result As TransferOperationResult
With sftp
    .HostName = "***"
    .UserName = "***"
    .Password = "***"
    .SshHostKeyFingerprint = "***"
End With
session.Open(sftp)
transfer.ResumeSupport = TransferResumeSupport.Off  [property is readonly]
transfer.TransferMode = TransferMode.Binary
result = session.PutFiles("C:\xx.csv", "xx.csv", False, transfer)
result.Check()
Thank you.
fightingfit99
York
Don't worry, fixed it myself:
transfer.ResumeSupport.State = TransferResumeSupportState.Off
AnkitJetly
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
