[solved]How to ignore File or Folder Does Not Exist (put)
I launch winscp.com with a script option in a Process Task in an ETL tool.
In the script there is a put command. Sometimes the source file will be there, sometimes not. When the source file is missing winSCP returns 0 and the Process Task fails.
How to ignore if source File or Folder Does Not Exist (put) and still returning 0 for other errors ? Is there an option to do this (like -delete which is able to remove the source file) ?
Thanks for your help
a+, =)
-=Clement=-
Configuration : Winscp 4.35
a+, =)
-=Clement=-
