How to compress a directory with WinSCP using SCP protocol
minorgod
Tallahassee, FL
Here is the command I wrote to tar and gzip a directory. It does not delete the original directory. It prompts the user for the archive name, an exclusion pattern (can be blank) and a directory or filename to compress. You must be using SCP protocol for custom shell commands as SFTP doesn't allow it. You can add this as a custom command:
Description: Compress Directory
tar -czvf "!?&Enter an Archive Name:?archive.tgz!" --exclude="!?&Exclude files matching pattern:?*.exe!" "!?&Specify directory or file to compress:?!"
Re: How to compress a directory with WinSCP using SCP protocol
Thanks for your contribution. I'll add the command to the default custom commands.
