Install 5.0.8 or 5.0.9 over 5.0.7, cleans all previosly conf
mxsimpson
I have 5.0.7 installed and when I install versions 5.0.8 or 5.0.9, the program cleans all my configuration. The configuration is setted to a .INI file, and when I install a new version, the file still exist but seens that the program is not using it.
OS: Win 7.
Now I'm using 5.0.7 and the INI file is in the Program Files folder.
I've tried update to 5.1 and the same problem occurs.
mxsimpson
Solved!
I move de INI file from the program files foder to "C:\Users\USER\AppData\Local\VirtualStore\Program Files\WinSCP" and then winscp found it!
Why the location of the INI file changed?
May I suggest a Import button from INI file, like the button Export that already exist?
Thanks!
Re: Solved!
