Configure double click action?
Could it be made possible to define the default action on double click (currently switchable between Open and Copy), so that the other context menu entries (like F4 edit on the remote side) become default for double click?
Re: Configure double click action?
I even do not like the copy to be the default. I regret I was conviced to add the option. So I will not not add another one. I'm sorry.
prikryl, I understand and respect your opinion but adding this option would not do much harm to the software but could come quite handy to people like me. Any chance you could reconsider?
The explorer mode doesn't work well with copy being the default option for double-click.
What I really want (really, really want!) is the ability for double click to open the editor.
AND (more importantly!) the ability to configure different editors for different filetypes - It's annoying always opening jpeg files into notepad! Each editor would need to have it's own setting for whether it was a multi-windowed application or not.
Jolyon
why?
OK, I'll think about it.
Forget my previous post - for some reason 'Open' wasn't working on my work PC, it was defaulting to 'Copy', which was pointless.
Open does everything I need. Thanks!
